Question about Pioneer Audio Players & Recorders
Pioneer stereo tuner amp sx-p720 power supply schematic diagram
  • 486 Answers
You can get full schematic about your device using this link:
http://elektrotanya.com/pioneer_sx-p720_920_sm.pdf/download.html
Good luck, good work!
Thanks.
gylacz
Posted on Jun 24, 2011
6ya staff
SOURCE:
Pioneer sx-850 goes into protection after several minutes of use. It seems to be after warm up or when room temperature is too high. Summer temps.
Did you check whether the protection assy is working properly? The protection circuit is checking the current of the power transistors as far as I remeber. So there are several possibilities for that fault.
You should grab the service manual or at least schematic (http://elektrotanya.com/pioneer_sx-850_sch.pdf/download.html) and then go step-by-step. I recommend to start up with the protection assy itself. If this works properly go for the power amp. It is also not unlikely that the power supply is the cause of the problem.
Good luck.
Dec 05, 2013 | Pioneer Vintage Sx 850 Stereo Receiver...
Put to big of a fuse in my pioneer sx-203 and burt out a cucit
Using a higher voltage fuse is not a problem, but if the fuse you used amps are to high, that is a problem. Sounds like a resister burnt. You have a short somewhere in that particular circuit, which is what took out your original fuse. . .your fuse did it's job by blowing and saving the circuit. If you can get your hands on a schematic, you can trace the circuit and find the short.
Jul 12, 2012 | Pioneer SX-205 Receiver
Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Jan 17, 2010 | Pioneer SX-255R Receiver
Wiring
Hello nootkabear,
Without the model number of your super tuner, it's not possible to point you to a specific location for the wiring diagram.
I'd start with Pioneer support to see if they have a download for the manual. If that fails, try the manualsonline site. Manualsonline is not a free site.
Hope this helps.
May 30, 2009 | Pioneer Car Audio & Video
Need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Apr 25, 2009 | Car Audio & Video
Pioneer sx-40 receiver
You appear to be pretty savy but your best bet is to get a hold of a schematic so you can really trouble shoot. Did you try a google search? Check with vintage gear sites? Pioneer?
Sep 17, 2017 | Audio Players & Recorders
Pioneer SX-950
Speaker Relay Output Switch was a common problem with most SX models of the 70's. It's the switch you hear click on after about 4 seconds of power switch being turned on. It's still avail. thru Pioneer parts for around $45.
Jul 28, 2008 | Pioneer AVIC-S1 GPS Receiver
Open Questions:
712 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
