SOURCE: I just purchased this humidifier.
Nicole, some of the packing material may have gotten into the drain tubing or hole and clogged it. Remove the water reservoir and look for a vinyl tube or drain hole in the cavity that the "bucket" came out of. If you can see anything blocking it, carefully remove it. I don't think at this point anything would have gotten any further down the drain tubing. Since this a brand new unit, consult your Owners Manual for directions on how to Troubleshoot this problem. If that fails, it's under warranty. Contact the manufacturer as directed in the Owners Manual.
Hope this helps to get your problem solved.
SOURCE: Model HD656E dehumidifier ran well
Hello
There should be a button on top for the fan speed,High and low.If your running it in automatic with say a humidity setting of 58 to 60,the fan will run low unless the unit sences say 70 to 80% humidity.
There is a filter in the back you may want to clean it, before you know it it will be hot and humid again.
To answer your question the unit is working fine.You can set the humidity level to its lowest point then try high speed,just for a test.
SOURCE: Haier 65 pt dehumidifier the lo light is on and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: My dehumidifier ices up and its not the room temp.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
SOURCE: I have almost brand new
I'm assuming that this isn't a Timer issue - make sure it's off.
LO signals that the humidity is set to the minimum available setting - 30%. Normally that should keep the unit continuously working since the humidity in a room never drops so low, unless you live in a desert.
Try raising it a bit (up to 50) and see what's happening. If the unit doesn't starts then the defect is in the control board or the compressor - you will need to open the unit and verify that the power is delivered to the compressor and its starter coil. For that you will have to check its starting capacitor. This service manual will help you
http://www.retrevo.com/d/df/document.pdf?doc=daa28f4e2ec0b9179acf8d9f9672a0ed&ts=1312144540907&rk=0.22809628064164034
But i must warn you: if your unit is brand new you shouldn't touch or open it or the warranty will be voided - in that case contact the ones that sold it to you or the company that is providing the service, they will pick it up and fix it for free.
Q -
Will my dehumidifier work in a cold room ?
A -
A dehumidifier will not operate satisfactory in a room that is
below 65 degrees F. At this temperature it will become necessary to operate the
dehumidifying coil below freezing temperatures in order to reduce the relative humidity to
a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
