Question about Kodak EasyShare C360 Digital Camera
Cards not working with camera
Why aren't my Secure Digital (SD) or MultiMedia (MMC) memory cards working in my EasyShare digital camera when they worked in my other camera?
  • Anonymous Mar 27, 2014
    mmc memory card
    Scholar:
  • 114 Answers
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Posted on Aug 29, 2005
I had a similair problem with my memory card and kodak camera.
I solved it by formatting the card in a camcorder that takes sd cards.
hope this helps
Posted on Oct 12, 2008
Anonymous
  • 114 Answers
SOURCE: camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Where can I get a card
Your hp photosmart m417 can use a secure digital (sd) memory card or a multimedia memory card (mmc), per manufacturer specifications.
Probably obtainable from local camera stores, computer stores, or via Ebay.
Mar 18, 2016 | HP Photosmart M417 Digital Camera
What memory card can i put in my easyshare c875 kodak
The C875 works with MMC and SD cards. MMC cards are going obsolete, so you'll probably not be able to find many of them. When getting an SD card, make sure it's not an SDHC card. SD cards top out at 2GB while SDHC cards start at 4GB and go up from there. SDHC cards will not work in the C875.
Aug 29, 2011 | Kodak EasyShare C875 Digital Camera
What memory card should i put in a kodak easyshare c530 camera
Kodak easyshare c530 has SD/MMC card expansion slot. So you can use any SD(secure digital) or MMC(multimedia cards) storage devices.
Sample pics below: bourngenius_20.jpgSD bourngenius_21.jpgmmc
Feb 14, 2011 | Kodak EasyShare C315 Digital Camera
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
Jan 21, 2011 | Kodak EasyShare C643 Digital Camera
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Storing or formating SD card
The Secure Digital (SD) memory card has a write-protect switch on the card case. Like the write-protect switch on a floppy disk, the SD switch prevents the card from being written to. (The SD card is slightly thicker than the MultiMedia [MMC] card.) Moving the write-protect switch will allow you to write to and format the SD card. If you are looking at the front of the card, the switch is on the upper-left side.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
2,033 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
