SOURCE: not enough memory coming on nokia 7210 supernova
Hi to solve this problem you have to format your phone as well as memory card also
SOURCE: nokia 7210 supernova in open the music player to
software problem.if u hv backup insttaled them
SOURCE: Sir my nokia 7210 supernova
phone memory has limited space.if phone memory is about to full.this type of problem occur.you should move some item from phone memory to memory card.after that go to music menu.selects options>update library.after updating press ok.your problem will be solved.
SOURCE: I have nokia supernova 7210. Not Enough Memory msg
try the restore factory settings via the settings menu. It is a software error. just backup the important files, after that, it should be ok again.
