The histogram is a tool that is useful to the photographer that shows a graph that represents how much color or bright and dark areas are in a photo. If you're looking at a photo that has a larger portion of the histogram graph on the left, it means there's a lot of dark / black tones - and that details in those areas are likely lost. The same holds true if the graph was heavy to the right edge - but it would mean there is a lot of bright or whites. Subtle details in these areas would also be lost. You can use the graph to adjust your exposure so that these details are visible. A wedding dress that lacks the fine lace details because the whites were "blown" (over-exposed) lacks interest when compared to a photo that preserves the details. Here's a link to a site with some great info in general - and about histograms specifically. Check it out.
Tinker with exposure settings to move the large areas of the graph away from the edges - this will show the details. You can switch the histogram off and on as you see fit.
Made by Microsoft, used for creating, opening and managing spreadsheet data files created with the application. Spreadsheets allow you to manipulate numbers, formulas, information and extrapolate resulting information, graphs, charts, organized lists, export data to create all sorts of useful results. Not sure what else you want to know...
A histogram is a particular type of bar graph used to represent the distribution of a set of data. However, the BA II Plus is not a graphing calculator, so you will not be able to create a histogram on it.
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
ms excel is a program that you can make graphs and set up all sorts of things like prices at a petrol station on the front neon sign you can set it up that each time the price rises it will automatically increase that rise in dollars and cents
hope this helps
To create a tally chart in a laptop,the laptop must a spreadsheet package like Microsoft excel
these are the steps involve -select the data to be use for graph.include the column and row label in sections -select data -click on number tab -click on text -click ok -click on chart wizard icon on the tool bar or click on insert on menu bar click on standard tab or custom types tab under chart type list ,click to select the desire chart type eg tally. under chart sub -type list,click to select the chart desire. click on next button. click on data range tab under series to select rows or columns. click on next button. that solve it.I hope you"ll find the solution post useful,dont forget to leave your comment by saying hope hopeful this post is to you
Choose the data in which you want to graph by highlighting said data, including and row/column headings. Then click the icon, which looks like a graph, in the top toolbar which will open up the Chart and Graph Wizard. Then follow the steps and guidelines to create your chart or graph.
i have 2 columns in an excel. One column has data like a,b,c,d,e,f,g,h,i,j,k,l and the other column has values like 0,1,2,3,0,0,0,0,0,5,8,0 respectively. Now i have to generate a graph(pie chart and column chart). But the graphs should not have data and values that have 0 values. i.e, the graph should contain these data and values respectively. data: b,c,d,j,k values: 1,2,3,5,8.
