Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging. Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected). The connector will be labeled at the micro usb end. When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Try to plug it to other USB port of your PC I recommend you plug it at the USB port at the back of your CPU..If this doesn't solve the problem try to clean your DVD drive lenses with a DVD cleaning disc..Still if this doesn't solve the problem perhaps you'll need to contact a technician or for worse buy a new external DVD..Hope it will help you..
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
