It seems that the problem lays on your Ram,not the graphic card.And since the driver of graphics card is capturing some of your ram memory you are experiencing this error.
1. Go to your bios by pressing delete or F2 key.
2. Go to Chipset tab.
3. Go to North Bridge enter, IGD currently Enabled press enter and select Disabled.
4. Press F10 to Save and Exit keeping your changes.
The set up above is a sample BIOS settings for Biostar H55 mother board,used as a reference to show how to disable the integrated graphics card. it might be a conflict to your 1GB DDR2 GPU.
additionalInitiate Graphic Adapter This item allows you to select which graphics controller to use as the primary boot
device.
Options: PEG/PCI (Default) / IGD / PCI/IGD / PCI/PEG / PEG/IGD
as you can see most mother boards now a days can work well with integrated GPU and discrete GPU so it's up to you if you want to disable the IGD or same.
If you want to verify the running GPU's right click on My Computer, Properties, Device Manager, Click Display Drivers and see what GPU's are running.
Hopefully this information helps.
Willing to help if problem persist, just give more details or specifications.
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
