I assume you tried hitting the delete key while it was booting. Also you need to use a keyboard that is NOT usb. The usb drivers were deleted during the format. The pc will probably not boot if it does not see a keyboard. Also make sure you are not using a usb hub and remove all usb devices. Disconnect all devices except keyboard and mouse and monitor and try again.
Thanks for using FixYa
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Thanks for your responce. I had not tried the delete key but come to find out it was a ram card issue. I am curious as to what that function that preforms?
