SOURCE: HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
SOURCE: Have a motherboard in my
Seems like the 2.2 is a new version. It supports a Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
The link below has the specs of your original MOBO...
http://www.softunique.com/ECS-MCP61PM-HM-Nettle3-GL8E-Motherboard-HP-ver-22-MCP61PM-HM-V22.htm
Here are the 1.0B specs:
MCP61PM-HM REV:1.0B SOCKET AM2 MOTHERBOARD
Motherboard description Motherboard manufacturer's name: ECS MCP61PM-HM
HP/Compaq name: Nettle-GL8E
CPU/Processor Socket: AM2
Supports the following processors:
Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt)
Athlon 64 less than 4000+
Sempron less than 4000+
Front-side bus (FSB) 2000MT/s (2.0 GT/s)
Chipset NVIDIA GeForce 6150SE nForce 430
BIOS features System BIOS core brand: Award
Keyboard combination to used to enter BIOS: F10
Form factor Micro-ATX: 9.6 in X 9.6 in
Memory Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
Non-ECC memory only, unbuffered
supports 2GB DDR2 DIMMs
Supports up to 8 GB on 64 bit PCs
Supports up to 4 GB* on 32 bit PCs
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: NECESITO EL MANUAL DE
NECESITO EL MANUAL DE Placa base 945GCT-HM PARA CONECTAR LOS CABLES DE PW ETC DE ESTA PLACA
Thanks, Joe
