SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I have the Singer Touch Tronic 2001. I bought it used for $50. It has the manual and all the parts. However, the manual refers to lifting the top console to access the stitch width selector dial and to change the pattern selector discs. I cannot seem to lift this console up even the manual says that it is hinged for easy access to these parts. Can anyone describe how to lift the console up? Or send a picture or video of this process?
Most appreciated!
