Tip & How-To about Genie Company IntelliCode GICT390-1BL Remote Control
USE ONLY WITH SERIES II ELECTRONICS.
Older Transmitters and Receivers will not work with these new
electronics. There are no Security Code Switches inside the Door
Operators, Transmitters and Receivers.
To Program Receiver
Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.
Step 2-2 Press a Transmitter Button once within 30 seconds.
Step 2-3 Press and release the Learn Code Button
• The Radio Signal Indicator will blink approximately 2 times per second.
• The Radio Signal Indicator stays lit - SOLID.
Step 2-4 Press the same Transmitter Button within 30 seconds.
• Radio Signal Indicator will go out.
NOTE: If a second Transmitter Code is not confirmed within 30 seconds or
if a different Transmitter Code is sent, the Radio Signal Indicator
will blink approximately 4 times per second, then programming will
stop. If programming stops, repeat Steps 2-2 through 2-4.
Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.
NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access
device Codes can be stored into Receiver Memory at one time. If a
Transmitter becomes lost or if you want to delete a Transmitter,
Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER
MEMORY.
Multi-Button Transmitters
NOTE: Only ONE button of a Multi-Button Transmitter can be programmed
into a single Receiver. The other buttons are to control other Door
Operators.
NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL
Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver
with the remaining Transmitters Codes.
Erasing All Receiver Memory
Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.
ALL Transmitter Codes are erased from Receiver memory.
Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).
Step 5-1 Battery replacement
• Slide Battery Cover off of Transmitter back.
• Replace with new batteries.
• Slide Battery Cover back on.
Step 5-2 Visor Clip installation
• Slide Visor Clip into back of transmitter until it snaps into
place.
