SOURCE: I have a GPS navigation system ITEM NO W3G-01
In the product manual it indicates there is a SD card slot, along with a USB port, so there is a physical method to change the map data to your locale.
http://www.nextar.com/images/Product/W3G-01%20hardware%20manual-english.pdf
However, you should contact the manufacturer to see if their firmware allows you to change/add maps. Garmin GPS units have this capability, and I have used their topo & Road maps together with very good results for off-road adventures out in AZ & Utah.
SOURCE: HAVE RADIO SHACK DIGITAL TRUNKING SCANNER, WHAT
You cannot pick up cell phone conversations on your scanner. Federal law prohibits the manufacture and sale of scanners capable of receiving cellular bands, and modern scanners cannot be modified to include those frequencies Sorry. . . .
SOURCE: will uniden digital trunking scanner pickup kenwood radio signal
Makes and models make no difference as far as compatibility. Check the frequency coverage of the scanner you're looking at, and compare it to the operating frequencies of the Kenwood. If the Kenwwod is an HF model, the answer is a flat NO. If it's VHF or UHF, most Uniden scanners will be capable of reception. If you need more specific info, such as operating frequencies/modes for specific radios, please let us know.
SOURCE: How do I look for Police frequencies on my Radio
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
BillB
SOURCE: I can recieve my United Kingdom hotmail on my samsung jet but I
hi, try to these settings for your mobile
from your phone.
1. press message
2. under message, scroll down and select settings
3. under settings, select email
4. under email, select email accounts
5. under email accounts, select create and fill up the following boxes.
6. Account Name = Hotmail
7. SMTP server = smtp.hotmail.co.uk
8. SMTP port = 587
9. Secure Connection = SSL
10. Incoming Server type = pop3
11. Pop server = pop.hotmail.co.uk
12. Pop3 Port = 995
13. APOP log in = checked
14. Secure connection = SSL
15. Download limit = 500 (configure to your own liking)
16. Retrieving option = Subject Only
17. keep on server = checked
18. my address = your email add
19. user name = your email add
20. password = your password
press save and press back and press back again to return to email menu. select profiles, configure your internet access or configure it to your network provider internet access. return to message menu, select email inbox, select your email account and press download and check.
hope this will help you.
