Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
