Hi i want to update my nokia 7210 supernova software in my mobile when i had connected the data cable to my computer and mobile . i had broad band connection to my computer .please tell me
When you tried to reset or format your phone,your phone content such as calculator,wallpapers etc. will be erase. All you have to to is update the phone firmware using a Software .you also need a data.usb cable,full charge battery and a stable internet connection.
Here's how it works :
* First you need to download this software : NOKIA PC SUITE
* install the software and run it after
* turn ON the phone and plug the usb cable to your phone and thru the computer.
* Some driver will be installing,wait until it is recognized.
* Now follow step by step procedure until you need to start,be sure the above requirement follows.
* wait until the process is done and now check your phone,all content you are looking for is their.
he
7210 Supernova is a tri-band phone working on the 900, 1800 and 1900
MHz bands. In the UK they use 850 and 1900 MHz bands (as opposed to 900
and 1800 in India and pretty much everywhere except North America).
If you can pick up an operator using the 1900 MHz band you'll be fine. If not, you're out of luck.
If
you want full GSM coverage both in India and in the UK then you need a
quad-band phone. The 7210 Supernova doesn't fit the bill.
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. OR: Reset factory setting with nokia flasher box. Thanks
I am using nokia 7210 supernova . When i am opening musicplayer it
showing operation failed error and not playing. How can i resolve this
problem i updated my mobile software also.
