2003 Harley Davidson FXDWG Dyna Wide Glide Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to disarm security on a dyna wide glide - 2003 Harley Davidson FXDWG Dyna Wide Glide
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on Jun 21, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1014093
Points
10058
If I remember right , this will work for your bike, Step 1: Turn ign key on-off-on-off-on
Step 2: Press left turn signal 2 times and release
confirmation: 2 or 3 flashes on turn signals (depending on
configuration) 2 for USA, 3 for everything else
Step 3: Press and hold key fob button until confirmation recieved
Confirmation: 1 flash on turn signals
Step 4: Repeat step 3
Confirmation: 2 flashes on turn sigals
Step 5: Press left turn signal 1 time and release
Confirmation: Turn signals flash to indicate option selected:
1 flash - Auto arming disabled
2 flashes - auto arming enabled
Step 6: Repeat step 5 to switch between auto / auto off
Step 7: Turn IGN switch off
2007 Harley Davidson FXDWG Dyna Wide Glide alarm will not disable @
Hi, Charles for this scenario you will need your service manual that has all fastener torque specs -fluid capacities and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day.
https://www.youtube.com/watch?v=nu4jGJ_reBA
http://www.mediafire.com/file/jl8r784mf99v62w/2007+Harley+Dyna+Service+Manual.pdf
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/wide-glide-2007-owners-manual-66493
https://www.6ya.com/how-6ya-works to speak to me personally.
2008 Harley Davidson FXDWG Dyna Wide Glide no spark @
Hi, Dana and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. A faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.v-twinforum.com/threads/no-spark-no-start-wideglide.506458/#post-5434226
http://kt-trading.net/mcimport/mc/HD/HD.Service.Manual.Dyna.pdf
https://ownersmanuals2.com/harley-davidson/dyna-wide-glide-105th-anniversary-edition-2008-owners-manual-66532
How do i disconnect the alarm system on my dyna wide glide
A person would need to know the year as a starter and then just what you mean. Do you want to disconnect a srien or disarm the systme or disable the system completely???
2001 Harley Davidson FXDWG Dyna Wide Glide no spark @
Hi, Anonymous and the usual suspects are:
https://www.hdforums.com/forum/dyna-glide-models/1037786-2000-dyna-no-spark-won-t-start.html
http://www.mediafire.com/file/g3h2vn0nvw3b5wb/2001_Harley_Dyna_Service_Manual.pdf/file
https://serviceinfo.harley-davidson.com/sip/service/document/6300
2helpful
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
