Haier AHD25 Dehumidifier Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dehumidifier keeps icing up, I have tried cleaning the coils but this has not helped.
Anonymous
Level 2:
Sergeant:
  • Expert 229 Answers
  • Posted on Jun 21, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
229
Questions
Helped
48067
Points
660
This is because your system most likely has a leak in the refrigeration lines. Buy a new dehumidifier its not worth fixing invest in a new one. Humidifiers are made very cheap they really dont last.
Wht does my dehumidifier keeps getting ice build up
Possibly dirty. Remove and clean all the filter parts and inner coil.
Be careful not to damage any of the cooling surface area.
Most of the time, you will get improper airflow from blockage.
Completely clean and try after to see if this corrects this issue.
Oh, a new filter if you have one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Coil keeps freezing up. ie. coated with ice!
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
1helpful
2answers
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
3helpful
How do I clean the dehumidifier?
A dehumidifier works just the way an air conditioner works but in a reverse manner. If you encounter a problem with your dehumidifier then it would be repaired the same way you would repair an air conditioner. As such a dehumidifier does not require much cleaning apart from changing the filter. When the filter and coils of the dehumidifier are choked with dirt, it may not pull out moisture from the air properly. The efficiency of the dehumidifier gets decreased and the only solution is, to clean it thoroughly. In order to assist you with the cleaning procedure of a dehumidifier, following are a few tips:
  1. Remove the water tank/container and clean it after draining the water. Depending on the usage the container must be cleaned regularly.
  2. Cleaning or changing the filter is also important for the main function of ensuring a healthy atmosphere is performed by the filter. Mix some bleach with warm soapy and clean the filter. It will help to get rid of the bacteria, molds and mildew.
  3. Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off the dirt using a brush but make sure that you don’t bend the fins while cleaning.
  4. Clean the condenser or the cold coil the same way. If the humidifier is working in a room where the temperature is below 60 degrees Fahrenheit then check the coils whether it is not icing up.
  5. See to it whether the fins are bent or not, if they are bent then straighten them out using a fin comb otherwise it might obstruct the effective working of the dehumidifier.
  6. And yes do not forget to clean the fan blades and other parts of the dehumidifier.
  7. Keeping in mind the humidity level of your room, sets the humidistat of the dehumidifier as keeping it too low or too high may only make the dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Icing up on our dehumidifier
typically happens when there is a lot of dust in air. Try cleaning it VERY well, which would mean, shutting it for a few days, letting it melt and dry off, then not only vacuuming it, but then take an air gun (or Air in a can) and get the dust off the coils. Obviously if there is a filter clean it, or replace it.
Check for bent fins on the coil. Most of the newer ones (and yours should as well) have an auto defrost to help with that.
Good luck
9helpful
2answers
LG dehumidifier developing ice
First you would need to clean the filter. LG recommends cleaning the filter every 2 weeks on their dehumidifiers. The second thing you need to do is clean the coils periodically. On this dehumidifier it should include a brush for cleaning the coils. It is located on the top of the bucket. To access the coils the following needs to be done:
1.) Unplug the unit from power
2.) Remove the bucket and also the air filter
3.) Remove the front pannel by removing the 2 lower screws and depressing the tabs.
4.) Once the panel is removed you will see the coils. You need to clean them with the brush. Go in an up and down motion to remove the dirt and dust.
Now use the reverse steps to put it back together. If your dehumidifier runs often I recommend you clean the coils about every 3 to 4 months. This is a common problem on alot of dehumidifiers and people think their dehumidifier is broken. Most of the time the coils are just dirty which causes the water to stay between them and freeze. Keep me posted. Also if you found this response helpful, please rate this solution when you get a chance. Thanks - Tech101
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
