Intermatic 10 Amp Mechanical Indoor Timer  Logo
Posted on Jun 21, 2011
With my lamp timer model TN300, what is the difference between options "Timer On" vs. "Outlet On?"
A
Anonymous
Timer ON is when you want the timer to turn lamp on-off.
Outlet ON is when you want to control lamp with lamp switch
http://waterheatertimer.org/How-to-set-timers.html
How do I set the woods tn300 timer
just found this on the fixya site not sure if its what you are looking for.
Woods TN300 and Intermatic TN300 and Woods 59200 are same timer:
To confirm this is your timer, open link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
If this is not your timer, then add a comment for additional free service.
Instructions:
Rotate dial to set current time, when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour. Push segment down like piano key.
Segment pulled up = lights OFF
Segment down = lights ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
Open following link for instructions how to set analog timers.
3helpful
I lost instructions for Woods TN300. How do I set it?? THANKS and HAPPY NEW YEARS to all and BE SAFE!!!
Instructions:
Turn lamp ON
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone to help you solve problems
I HAVE INTERMATIC MODELTN300 and don't know how to set it up,
Intermatic TN300 timer is same as Woods 59200 timer
See timer at Amazon
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Timers are sold under different brands and numbers depending on who is packaging and marketing the product.
59300 manual:
http://waterheatertimer.org/pdf/Woods-59200.pdf
Turn lamp ON
If instructions above don't match your timer, see following page to identify timer:
4helpful
I neeed the instructios for woods timer TN300 thanks
59300 manual:
Turn lamp ON
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Turn lamp ON
12helpful
Have a new woods tn300 light timer. if lift the
Anywhere that pegs are pulled up is where the outlet is off if the pegs are down then the outlet is on. Hope that helps!
Not running when I set it
Open following link to identify Woods and Intermatic TN300 manuals and see written instructions.
For troubleshooting instructions and photos of timer dials.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
