Check the fuel tank vent is not obstructed. Also consider if overheated could be vapor lock in the fuel line.
Good day. I do not know when the machine was last serviced, but it sounds to me like a fuel filter problem. If the fuel filter is clogged, it might battle to get fuel through the hose, and seeing as it is a gravity feed form the tank to the carburettor, it might be the reason the machine chokes on inclines. Replace the fuel filter (taking note of the diredtion of flow) and get yourself a tin of carburettor cleaner and spray directly into the carburettor's ports. Hope this helps
I don't know about that as it has only done four hours work and the agent says it is not due for it's first service until it has down 8 hours. Agent also said that it some times happened but after paying that amount of money I am not preparted to accept that. I have had heaps of ride on mowers and this is the first time this has hapened.
cheers
I don't know about that as it has only done four hours work and the agent says it is not due for it's first service until it has down 8 hours. Agent also said that it some times happened but after paying that amount of money I am not preparted to accept that. I have had heaps of ride on mowers and this is the first time this has hapened. cheers Thank You!Was the solution helpful?Show your appreciation by commenting on Hi, I have a new:
I don't want to Accept this solution
?Continue working with this Expert by posting more comments - Reply to micmor100
?No, I want to work with a new Expert - Ask Another Expert
X
Are you sure you want to withdraw your problem?You should only withdraw your problem if no Expert is giving you a satisfactory solution for this problem, and you would like to post another problem. If you want to continue working on this problem with another Expert, Go Back, and pick the Ask Another Expert option. back
X
Absolutely, I now have an idea and it will easier not to be fobbed off by the salesman.
