SOURCE: computer locked as though in
Remove the battery and mains and hold the power button down for 30-60 secs, then replace battery and mains. It should now hopefully turn on.
SOURCE: my msi u100 notebook when i turn it on it says
Hello my friend,this is looks like the windows is corrupted and your windows cannot boot ,maybe this is caused by a virus,you can try reinstalling the windows but i don't recommend it if its a virus problem.I recommend you formatting your computer or restore your laptop to factory settings.The last one it depends on laptop some have special restore partitions on the hard drive, usually you press alt+F10,F10,F11 or F12 after powering on the laptop, and it goes into a restore program that wipes your drive and returns the laptop back to the way it was when you first purchased it.
Note all your programs and data will be deleted if you restore the computer.
SOURCE: hi i have an msi
The moon icon usually indicates that your machine is in SLEEP mode. Try closing and opening the screen lid. If not, there might be a problem with your laptop waking up from sleep mode. Try holding the power button. This will turn it off. Turn it on again by pressing the power button once more. Hope this helps! Have a nice day.
SOURCE: my msi u210 stays black
Hi malbasmunchy,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Testimonial: "thank"
