The drum insde that rotates, is usually held in place by three or four
big springs or rubber shock absorbers so that it can move a little but
not too much, and if they have come loose or got old, the drum will have
more freedom to move about, especially if all the clothes are at one
point in the drum. Sometimes there is an adjuster device which consists
of two nuts on a threaded bar that can be unlocked from each other, move
along a bit then tightened together again. other types of adjuster
exist but are usually more difficult to adjust, and some don't have and
adjustment. If the maximum adjustment has been reached or there is no
adjustment, you will probably need to change the springs/shock
absorbers. please do not proceed to open the unit unless it is outside its guarantee period as doing so whilst still under
guarantee may void that guarantee. If it is still under guarantee, phone
the seller and describe the situation to them, they have almost
certainly had this situation before and should repair or replace it. If
you have been washing trainers in it, don't mention that to them ;o)
You can click on the link below to find a detailed breakdown down diagram of your dryer. there are actually 5 models that come under the DBL333EA family.... so choose your model from the list given and if you need to replace any part... you can always get it from the same website....
http://www.searspartsdirect.com/partsdirect/part-model/DBL333EA?pathTaken=modelSearch&prst=0&shdMod=DBL333EA
Thanks
Here
is a tip that I wrote about dryers and noises...
It will help
you determine what is happening there...
Dryer
Repair Squeaks,
Grinding, Clicking and Knocking Noise
heatman101
Asker's
Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
