For Time Warner Cable TV Remote Codes for DAEWOO-TV's - • Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html • Then select TW Cable remote model. • Under Control a Device -- first select type of device (TV) • Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. • Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
SOURCE: Tivo remote code for Daewoo Tv
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Daewoo TV is one of the following numbers: 0092, 0451, 0672, 1661, 1278.
If these numbers do not work, I would consider buying a newer universal remote. They can be bought at Walmart, for less than 10 dollars.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
SOURCE: I need the tv code
Just test them all: 0130 0004 0009 0100 0005
....0138 0043 0140 0039 0444 0080 0042
....0058 0017 0010 0126 0018 0127 0019..
I took this information from:
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Gl
Isn't there a wevsite that will allow us FREE access to DAEWOO 13" TV Model DTQ-13P2FC?emote codes?
For Time Warner Cable TV Remote Codes for DAEWOO-TV's -- Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is . Then select TWCable remote model. Under Control a Device -- first select type of device (TV) and then select Brand Name (DAEWOO). TW Cable lists several codes for different models. There were several codes to choose from and try inputting into myTW Cable remote. Finally, the next to last code worked on my TWCable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for this Daewoo TV Model DTQ-13P2FC is 1661. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free. Hope this helps.
Message failed to post URL web address for the TWCable web site residential technical support So here goes again... Web site ishttp://www.timewarnercable.com/en/reside... Good Luck!
