Vacuums Logo
A
Anonymous Posted on Jun 21, 2011
Keeps tripping the breaker. - Vacuums
Anonymous
Level 2:
  • Expert 300 Answers
  • Posted on Jun 21, 2011
Anonymous
Expert
Level 2:
Answers
300
Questions
Helped
98821
Points
787
It would have been nice to know what breaker you're talking about.
You may wish to elaborate a little in your next question.
It's not like sending a telegram where you pay by the word.
Asking questions here is FREE.
My Kenmore Elite Upright Vacuum stopped working.
It might sound very easy , but lack of power is usually the cause of a vacuum cleaner that is not working . Check that the vacuum cleaner is plugged into a working power outlet and that fuses and breakers don't need resetting. An activated thermal cut-out due to a blockage is the next most likely cause of the problem.
Tripped Circuit Breaker/ Blown Fuse
Check service panel for tripped breakers/blown fuses. If breaker is tripped, reset it. If fuse is blown, replace it. If vacuum cleaner is plugged in, make sure that the power button is in the off position before having to reset the breaker/changing fuse.
2answers
3answers
Breaker keeps tripping
If you can unplug the central vac and plug it into a different outlet that you know is on a different breaker and test it out to see if it trips the breaker,or temporarily rewire the central vac to a different power supply.Make sure the breaker is the correct amperage for the central vac,last read the instructions to see if you need a dedicated circuit breaker,you might have to many accessories plugged into that outlet.
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
My series 90L suddenly stopped and would not restart. A check of the circuit breaker found it tripped. The vac would not turn on when the circuit breaker reset. Using an AC voltage sensor indicated power...
From the description it sounds as if there had to be a short in the unit somewhere. This is what would have tripped the breaker. the fact that it is not tripping could mean that there is a fusible link or that the wires or whatever have burned back from the short, and are no longer shorting out.
Jul 04, 2011 • Vacuums
The circuit breaker on the unit pops almost every time I use the unit, what might be causing this?
Hi, when the breaker trips every time you turn it on, the unit has a dead short. It may have a frayed wire where it goes into the units motor, or the motor it self may be shorted out.A bare hot wire that touches metal will pop the breaker right away. I would look the cord over very well to see if anything may be bare. If not, the problem is further into the motor section of the unit, and more then likely the motor has failed. This is why the breaker is there for this reason. In case it overloads or you have a short, it trips to keep the unit from burning. Please keep me posted.
Sincerely,
Shastalaker7
Feb 05, 2010 • Vacuums
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
