Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board/door switch that needs replacement. Please get back to me if you have any other questions.
Kevin
You have a burnt,broken or loose wire in there somewhere...finding it can be a real chore...in fact the only way you may find it will be to use an electrical meter and trace the power...even then it can be time consuming and difficult...
This type of problem often comes from using the "self cleaning" feature on your oven and often happens right after using it, as that is when the wires get too hot and burn.....
It also happens with age as the wires heat and cool and then the terminals start to loosen up and no longer make good contact....
You can sometimes find the loose wire by moving them around while the power is on, but this can be extremely dangerous!!!
Heatman101
Display blank then ' t ' lights up faintly followed by 'stop' then goes blank again. I was thinking loose connection or faulty clock . If loose connection - could it possibly be an on circuit board fault .
Without fault finding chart it seems impossible to trace - Do you have access to/Can you send by email ?
Thanks
Dave
There is no self cleaning feature on this oven
Hi
Is ther any way you can provide a more targeted answer and provide Whirlpool engineer Fault finding chart
Thanks
Dave
Hi
Thanks for the reply. I was thinking along those lines but last night oven worked for 15 min . then display goes out flickers , comes back on flickers ,goes out then oven may work for a few minutes before going off and continues.....
Oven temp regulator wouldn't affect display would it ?
Many thanks
Dave
Hi
Thanks for the reply .
After approx 15min , Oven shuts off - display goes out at same time - display flickers dimly- display comes on -oven comes on and may work for a minute before repeating ?
Won't always come back on when door opened ??
any other possibilities ? programmer etc
Many thanks
Dave
Hi
Where is control board door switch located as unable to locate without schematic ?
Your help is very much appreciated
Regards
Dave
