Kitchen Appliances - Others Logo
Anonymous Posted on Jun 20, 2011
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 132 Answers
  • Posted on Jun 25, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
132
Questions
0
Helped
35885
Points
178
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
  • Anonymous Jun 26, 2011
    Rating our advice will let us know if we are doing you any good. Please take a moment to rate this advice. Thank you. And for all your U.S. and Canadian breadmaker needs visithttp://www.bread-maker.net/sitemap.htm
My new breadman pro breadmaker model TR875 did not come with an instruction manual. I cannot find one to download. Help.
hi. I had the same problem no manual and i did try a few other recipes with no luck, then i found this and have download it to my pc i think its about 58 pages so a bit large to print out..
mandi breadman ultimate File Format: PDF/Adobe AcrobatYour browser may not have a PDF reader ...
65.39.72.142/Term.aspx?t=21987
1helpful
Breadman TR875, the shaft fell out of the middle
Often these have a "C" clip that sits in a groove. These sometimes break. Pieces goes... somewhere... in the last loaf?
2answers
Breadman TR875 powers up but none of the buttons seem to
After powering it up, press and hold the start button (these are instructions from customer service). On a good machine this doesn't seem to reset anything. If this doesn't work, try holding in the start button while you plug it in and than release after a few seconds.
2answers
14helpful
TR875 paddle for breadman
I lost the kneading paddle - called the customer service number and they told there are none available and they are no longer making them.  Guess I just throw the whole unit in the garbage since it is worthless without a kneading paddle!!
Top Breadman Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
