The process of clearing these issues is very simple. Run IE 9 without any plug-in, add-ons or other extension. That is, if the software is yet to be installed. If it has already been installed then disable the add-ons. It is important to check what are the add ons that cause the crashing if that is the case; this can be done by clicking on 'Start', then on 'All programs', then on 'Accessories', then on 'System tools'. Click on Internet explorer again and again click on the 'Tools' option. Follow this by clicking on 'Manage add-ons'. There will be an option under show: all add ons. Open the option and click on any add on and press the 'CTRL + A' on the keyboard. That should help select all the add ons; once that is done simply disable all the add ons and click 'Close'. Finally close Internet Explorer and open it again. At this stage if it continues to open and work correctly then the add-on enabled manually will work properly and will stay! The constant problems of the browser crashing can be avoided.
Internet Explorer 9 Crashes Fix
Internet Explorer 9 crashes are caused by a number of problems that can occur inside Windows. Because this program is used by the Windows system itself, it's highly recommended that you're able to repair any of the potential problems that it may have, as well as ensuring that your computer is able to run as smoothly as possible with all the important options that it requires to operate. This tutorial is going to show you how to fix the errors that IE9 will often have.
What Causes Internet Explorer 9 Crashes?
How To Fix Internet Explorer 9 Crashes
Step 1 - Update Windows
The most important step to take is to update Windows. This will allow your computer to run much smoother, as it will be able to process the files and settings which it requires to operate the files it needs to run. To do this, you should follow these steps:
Step 2 - Disable & Re-Enable Internet Explorer 9
Step 3 - Clean Out The Registry
The most important step is to download a registry cleaner and let it fix any of the errors which Windows may have. A registry cleaner is a type of software which is able to scan through your system and get rid of the various problems that your system will have inside its "registry database". If you're experiencing problems with this part of your PC, it's important that you're able to clean out any of the problems that your system will have, in order to allow Internet Explorer 9 to work properly again.
I recommend you should download Frontline Registry Cleaner to fix the problems you're experiencing with Internet Explorer 9. This tool is the most effective at getting rid of the various problems that Windows may have with its registry - allowing your system to run much smoother as a result.
How about you uninstall IE9 and keep IE8 because it is perfectly fine! :)
