This kind of fault is only limited to a few causes.
First of all, it is not likely that all chargers you have tried are bad. So the fault is definitely coming from the phone. it is most likely that the charging port on the phone is bad and needs replacement of needs to be worked upon. This may not be very expensive depending on your location and the extent to which the damage has been done.
Also, it is very possible that the power source is not good enough to charge the phone. As such, you might be required to plug the phone's charger into a number of outlets that you are sure are operating fine. This would help you determine if the fault is coming from the charger, outlet or phone.
Lastly, if you are just trying random chargers, you would have to get a charger that you are confident is working and you have to try it. If it still doesn't work, you have to send it to a repairer as trying to fix the charging port yourself could let to a more serious damage to your phone.
Hope this was helpful?
