I have a Nikon coolpix and the nikon software installed on my mac. With the camera on and the USB cable connected into my computer, the software will load but no pictures will show up to transfer. Help please.
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
coolpix > L11_L10enPDF
May 15, 2007 - Thank you for your purchase of a Nikon COOLPIX L11/COOLPIX L10 digital camera. ... delete, or transfer pictures from the internal memory.135 pages
You first should remove the usb cable from the camera. Then check if you did not force anything in the camera USB connector. If so please remove , but not with a sharp tool. if that is not wrong. please remove the battery and after a few moments reinsert the battery and switch on again. If that also not works, go back to the dealer, or contact a Nikon certified repair centre.
When you connect the USB cable from the camera to the PC, the camera should shut down. If it doesn't perhaps your cable is defect. Or one of the connectors, from the camera or from the PC.
When the cable works on another PC (or Laptop) you can assume the cable is good. But then the USB connector in the PC could be not connected, or the USB controller in the PC is not working correct.
Sure you did install the Nikon software on the PC to?
First install the software of the camera to your computer it should be on the CD that came with the camera, then connect the camera via data cable USB and make sure the camera connectivity setting is USB connection. After that open the software and you should be able to see all the data inside the camera's memory and transfer it to your computer.
Nikon comes with a great deal of really good software for ALL Operating Systems. DO NOT have your camera attached and re install the software that came with your camera. You may also go to: http://www.nikon.com and receive a download of the software related to your camera. After installed, turn your camera ON - Then plug the USB cable into the computer and then into the computer.
Key Things To Remember: - Have Nikon Software Installed - Turn Camera On and set for Automatic Plug USB cable into Computer and then into camera
You don't need to download any software to your camera. You can download the current versions of all (free) Nikon software (for your Mac) here. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or Nikon Transfer or any other photo cataloging program.
sir u need a usb cord for connecting it withy comp.. not al usb can be used.. there are specific usb cords to be used. for eg nikon UC-E6 cables available in market.. also u need drivers.. download that from suitable site.. thank u
Did you install the drivers to the computer? And install the nikon software to your computer? If you didn't that is probably your problem. Otherwise you can get a cardreader and use it to get your photos on you computer.
You need USB cable to attache Nikon camera with your PC in USB port. Picture shows USB port in your camera and PC has USB ports at rear and possibly at front too.
