First of Open My computer-------on top of it you'll find Tools, click Tools--------Folder Option---------in General Tab at the end you'll find 'single click to open an item' just enable it and you are done. These steps are for Win xp.
In Xp --- you can go to control panel -----folder option--------under general tab just single click to open an itemand you are done.
for win 7 and win vista, Start------control panel -----folder option--------under general tab just enable single click to open an item and you are done
give me ranking if it works for you.
Hi. If your using Windows look in Controll Panel -Folder Options. You should find an option to single click to open files.
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
