Sharp ELW535 Calculator Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Enter a whole number with a fraction - Sharp ELW535 Calculator
Marlowe Amoguis
Level 2:
Sergeant:
  • Expert 405 Answers
  • Posted on Jun 20, 2011
Marlowe Amoguis
Expert
Level 2:
Sergeant:
Answers
405
Questions
0
Helped
105825
Points
988
Enter the whole number ,then hit ab/c on your calculator enter the upper number of the fraction then hit again ab/c then enter the lower number of the fraction.That way yuo can enter a mixed fraction.Hope this helps.
How to round to nearest tenth with the number 25,099
TenTH = A fraction of a whole, the 'th' tells that.
So, since 25,099 is a 'Whole' number, with No fraction of a whole, or no part/fraction of 1, therefor, rounded to the nearest tenth, it remains the same.
Do a search on why whole numbers are referred to as "whole" numbers.
Whole means complete, with no fraction part. 12, 37 are whole numbers. The number 12.5 contains a part that is whole (12) and a fraction part 0.5 equivalent to 1/2. There is no mystery.
Mixed numbers
If the result is positive, type in the integer part then add the fraction part either with the help of the fraction key or the division key. (I do not think that the TI82 has a fraction key.
If it is anything like the TI3 there is command under MATH >Frac. It should be pressed after you enter the mixed number to keep the result as a fraction.
If the mixed number is negative you enclose the whole number in parentheses. Press the change sign (-) key to negate the result.
1helpful
How do you enter mixed numbers ( whole numbers and fractions i.e 3 3/4)?
You cannot, you must enter 3.75. If you can't figure out what the fraction is, you must first compute the fraction (3/4=.75) and then add it to the whole number (3+.75=3.75)
1helpful
2answers
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
Can this convert decimal measurements to fractions of an inch
Enters a proper or improper fraction,
b?c (b { 6 digits, c { 3 digits). When
possible, improper fractions are
displayed as mixed numbers.
3 F 4 3?4
8 3 J 21?4
Single-variable functions display
decimal results.
1 F 2 0 0.25
a F b F c Enters the mixed fraction a b?c.
(a, b, c { 3 digits each, with the total
digits { 8).
6 F 4 F 6 64?6
J 62?3
"s Toggles display between a mixed
number and an improper fraction.
30 F 4 30?4
"s 71?2
"s 15?2
"s 71?2
"y Toggles display between fraction and
decimal.
55 F 24 55?24
"y 2.291666667
"y 27?24
If a result would overflow or if fixed decimal is 0, no
fraction to decimal conversion occurs. It is not an error.
Denominator must be a whole number {999.
2helpful
3answers
Can't find fraction button.
There is no fraction button, but if you divide two integers (whole numbers) and want to keep the result as a fraction press [MATH][1:|=>Frac] [ENTER]. If the fraction can be reduced to its simplest form that is the result you will have.
27/48 [MATH][1:|=>Frac][ENTER] displays 9/16
Hope it helps.
7helpful
2answers
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
1helpful
How do I divide fractions with the fx-300ms?
Look for button like [ a b/c ] it's the fraction first enter the whole number then press the button then the upper then the button and the down part, if you need only b/c so enter b press the button then enter c.
Rate me, thanks.
1helpful
2answers
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
