SOURCE: I have Toyota Parado Land
go to the toyota help forum they have trained technitions that can help
SOURCE: Chaging the language to English
turn on the camera, then go on menu right?
go to setup, then scroll down until you see language on the right side.then click on the right arrow (to highlight 'language'),and click on in once again to change te language, click on english, and wahhla!9 oh, and i 'think' click on ok after that. :)
SOURCE: language setting on olympus E-510
http://www.digitalcamerainfo.com/content/Olympus-EVOLT-E-510-Digital-Camera-Review-14157/Design--Layout.htm
SOURCE: Language setup
After trying on my own, I went back into setting by scrolling along until a picto gram - with what appears to be a machine bolt is highlighted and then pressed SET - next the screen shows a bunch of chinese words (these are the different languages) then I scrolled down to the last one - until its highlighted, - this is the english one - press the set button on the side of the frame, this will bring you back to the english menu.
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
