You just want to jump in start soldering without knowing what the cause is???
Do you even KNOW the speaker is the reason? Sources and cables can be the reason.
As always, you should refer to the manual FIRST before coming here.That is where WE will usually start.
For example, there is no troubleshooting section but there is a website mentioned on the last page: www.ilive.net
...which leads to SUPPORT (and contact information, should this not help) which leads to
http://www.ilive.net/store/p/43-2-1-Channel-Bar-Speaker-with-Dock-for-iPod-.aspx
which leads to downloadable manuals
http://www.ilive.net/owners_manual/IT188B-IB.pdf
an instructional insert for changing the clock between 12/24 hr time and FAQs, which discuss your symptom.
"Why can I not hear any audio from my iLive docking system?
When an auxiliary line-in cord is inserted into the LINE-IN jack (on the right side of your IT188B) you will not be able to hear what is connected to IN2 (on the back of your IT188B). Both of these input share the same input function of AV2. To play audio from either of these inputs, press the FUNCTION button until AV2 appears on your LCD screen. If both inputs have connections with audio players, the LINE-IN jack will have precedence over the IN2 jack. Make sure to detach the cable connected to LINE-IN before connecting a device to IN2. You will need an auxiliary line-in cable (3.5 mm mini to stereo RCA cable) to connect an iPod shuffle to this system. Also, there is a Volume Limit option in the Settings menu of your iPod. Make sure that this maximum volume is set to a range that will be audible. Be careful when adjusting your volume level. Higher decibel levels at close range may put you at risk for hearing damage."
I have my granddaughters IT188B with the same problem -- no audio. I have opened it up (if you don't mess with the transformer there are no dangerous voltages) and verified the 26V, 8V and 5V power supplies. Voltages around the quad audio power amp seem to be correct -- mute signal does the proper thing when the unit turns on and off (off is really only muted!). The voltages around the DIP8 audio amp on the PS/pwr amp PCB (on heatsink) don't make any sense however. Without schematics I'm not sure I can go much further. The audio/video I/O PCB has no circuitry except for the sub-woofer out -- so it's not the problem. Audio IN signals go the the RF PCB and then ?? Somewhere there must be a computer and (electronic) switches that select the various audio inputs. What gets to the output board is running the DIP8 dual audio amp into the rail. I'm not yet setup to do signal tracing/injection. Watch this forum for further results.
Mr. Hartsig, did you get any further on this, because I've got the same appliance, same problem (powers up, no output from any input, panel will charge iPod, and play/pause iPod) I got into mine, and like you said, all the inputs arrive at the RF section, and there's some digital circuitry on the rear side of the RF section (otherwise it looks like your typical AM-FM radio from the front). There's one shielded cord from there to the PS/pwr amp PCB (on heatsink). I think I'll feed audio into the amp at that point to check that, and also check for any output from the RF/switching section (hopefully OK, it looks more complicated to t-shoot w/o schematic). There's another comment here about the woofer's vibrations opening bad solder joints, My daughter mentioned that it worked, then maybe got jostled, then was scratchy audio, then was dead when I got it to fix.
Henry Dedrick
I got a static shock when I started to pull out the iPod. Now I have the problem reported here. Everything seems to work as displayed in the panel but no sound.
