If you replaced your sprinklers, did you use the same size nozzles as the original heads?
I need more information and I can help you with a well/sprinkler system problem.
Gary
I don't understand why it would drop after a few months. The impellar probably did not wear. It is more likely that the water level has dropped in the well, but this is unusual, too. If these heads rotate, they work best at around 50 psi at the head. There are small losses through the main piping, control valves and piping to the heads. If you can lower nozzle sizes on the heads to get around 50 - 55 psi at the pump, distance will increase. Try one zone and see the result.
Gary
Yes they are all as original .At first all zones had good distance for water discharge.After 2 months distance has been noticeably reduced.Also i instaled a gauge on the pump and reads 40psi on all 5 zones!!
