Thanks for your response when i turn on the tv i get a quick red and blue line for 2 seconds and then disappears and then the green light appears and stays there for as long as i have the tv on like a bow facing down the line is not in the middle it is coming from the upper part of the screen and going down about 6 inches and the in goes back to the top of the screen forming a bow like shape
some other tech at fixya have told me to Check fuses 1800 and 1801. Also check diodes 6809 and 6810 If there is High Voltage then replace Diode 6003 and Resistor
3669 when replacing the above parts also replace Diode 6012 and Diode
6025 they also tell me it is a defective vertical output
please let me know what you think
Thank you for your time
Hi
could you please tell me where are the vertical output IC and if they the same as the coverange ic
Thanks
