For their cost it's probably worth trying to replace the capacitors again.
If there's space around the capacitors then I suggest you get high voltage rating i.e if the existing ones are 16V then get 25V.
Also worth checking for any other damaged components or scorch marks on the PCB.
You can't get a replacement DM Board any longer. You may want to check that the DM Board is inserted into the guides correctly and pushed firmly home. Did you try increasing the voltage on the Caps? If you did then I suggest you've got a fault elsewhere that needs to be solved before you go any further.
I replaced them again and got about 2 days out of my tv until it went out again. Do you know anywhere I could get a replacement board? That would be the next thing I would try if it was not too expensive.
Thanks.
Ed
