Question about Powerwinch RC30 Trailer Winch
Brand new Powerwinch rc30. It worked fine, 2 times pulling my 21ft. Gradywhite onto the trailer. The third time failed- slipped clutch. Boat weight is 2900 lbs. without motor and fuel. Should I have used the double line/pulley attachment? Should I buy parts and fix winch or return to powerwinch for in warranty repair?
    Sergeant:
  • 331 Answers
I would try to get it repaired Under warranty.
And later use it in double line...
The weight of your boat is 1, the force needed to pull your boat on the trailer is another thing...
Posted on Dec 26, 2017
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: weight watcher scale not calibrating weight correctly
Hi there;
Flip the scale over and see if the switch is on kg or lbs. If it is on kg, switch it over to lbs and see if that fixes your problem.
HTH.
Posted on Oct 05, 2008
Meganerd X
Samuel
  • 117 Answers
SOURCE: how do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Posted on Oct 22, 2009
jeff
  • 122 Answers
SOURCE: After installing my new Powerwinch
have the wires crossed take the wires and switch the wires around
Posted on Jul 28, 2011
How do I get a boat trailer weight certified for the state of Florida?
Truck Stop weighbridge.
Getting a trailer weighed in Florida Page: 1 - iboats Boating ...
https://forums.iboats.com/...boating.../trailers...towing/360801-getting-a-trailer-weighe...
Sep 9, 2009 - I need to get my trailer weighed so i can register it as homemade. ... I think they may also require a law enforcement officer to look at it and certify its homemade. ... Most truckstops can provide you with a "Certified Weight".
Trailers (Vessels, Utility) ' Florida Tax Collector serving Sarasota County
https://www.sarasotataxcollector.com/services/motorist...trailer/trailers-vessels-utility *If the trailer was previously in a non-titled or non-registered state, the Bill of Sale should include year, make, TIN, certified weight slip and identify the state ...
[PDF]STATE OF FLORIDA DIVISION OF MOTORIST SERVICES
https://www.flhsmv.gov/pdf/forms/82105.pdf STATE OF FLORIDA. DIVISION OF MOTORIST SERVICES. CERTIFIED OFFICIAL WEIGHT AFFIDAVIT. NOTE: List ... (Year & Make of the Car, Truck, or Trailer).Missing: boat ‎' ‎Must include: ‎boat
get boat trailer weight certified for the state of Florida Google Search
Aug 24, 2018 | Boating
What is the weight of a 1981 21ft. Grew Boat Model 215
Going to between the 200 and 224. Weight is listed for both. You could just drop the boat and trailer on a weighbridge.
http://grew.ca/GrewBoats/
Aug 19, 2015 | Cars & Trucks
I need the boat and trailer (stock trailer) weight
Pull the trailer and boat to a scale and weigh it to get the exact weight. Most trucking companies,gravel yards, junk yards or even a state scale where they check for overweight trucks have scales to do that.
Apr 22, 2015 | Cars & Trucks
I just bought a new boat and need to buy a boat trailer. Should I buy a boat trailer with the weight capacity of my new boat, or do I need to make sure it can tow more than that just in case?
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
Oct 16, 2013 | Boating
My powerwinch brake won't release
you have to conscious of the fact that when dealing with water and equipment running in water there will be a distinct possibility of rusted bits. Winches have a brake system to hold the line in place when stopped so at a guess I would say that the release mechanism is rusted and not working properly. Try spraying in some wd-40 or crc tp see it that helps.
May 15, 2013 | Powerwinch RC30 Trailer Winch
Hi. I have to replace a roller of my boat trailer. I already bought a matching roller and was ready to replace it: then I found out it wasn't a bolt holding a bar that goes through roller. Some kind of...
that is a push cap rod end and you might find one at a local hardware. sometimes you can pry off and reuse them grip with visegrip and use a big screwdriver to pop it off . then tap back on with hammer .
Apr 13, 2010 | Boating
Getting a title for a vehicle
Different states have different laws. In states that charge trailer plates by Weight, you need to pull the Trailer over a scale and show the weight receipt. If the Boat has to stay on the trailer, pull both and subtract the weight of the boat from the total weight. You can find the Boat weight online.
In states that charge a flat fee for Trailer plates, its much simpler. You can also go to a Vehicle Registration center and get a form for the registration. But you need to call ahead to find out if Police or Highway Patrol can verify the Hull# or Trailer ID.
Mar 06, 2010 | Boating
I need to manufacture a boat trailer for a
I have some tips I learned from finding a trailer for my 27 foot cruiser. Really, you can find deals in this economy that make rigging a trailer from scratch too much work.
You need to find the loaded weight of your boat and where the hull needs support from Carver. Your trailer needs to hit the "Chines" correctly, meaning the bunks have to be adjustable to the contours of the hull.
The bunk supports can fit outside, inside, or on top the frame rails Mine started on top of the rails and were converted to the torsion axles, requiring new supports.
The axles need to support enough weight and State laws will say how many axles need brakes. Your choice of electric or hydraulic. The bunks should be made of Cypress, but synthetic decking could be cheaper. Your tires should Load rated D or better and 15 to 16 inch wheels, not 14 inch because of the weight.
There are numerous Boat Salvage yards listed online.
There seems to be a "thing" about the region the boats are used. Some places have orphaned trailers everywhere and others are always married to a trailer.
I have seen Boatyard liquidations with ridiculously cheap trailer prices. Use the internet and look.
Feb 06, 2010 | ShipShape Pontoon Boat Trailer Guide-on...
Loading back on traiker
Float on style trailers are designed with immersions depths and vertical guides to allow the boat to be driven onto the trailer. But not at full throttle, only enough power to move the boat over the bottom rollers/guides. Some trailers are designed to have the boat winched onto the trailer. For this style, you drive to boat to a starting point and then use the winch to pull the boat the remaining distance. These sometimes have a release mechanism and hinge/pivot point to allow the back of the trailer to drop below the normal towing position to make recovery easier. As the boat is winched into position, the weight of the boat will cause the trailor to pivot and return to the towing position.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Powerwinch RC30 Trailer Winch Logo
131 people viewed this question
Top Powerwinch Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Powerwinch Boating Expert? Answer questions, earn points and help others
