Not once but twice when the camera was on with the lens extended. The first time nothing happened to affect operation but the second time I got the lens error and the camera shut off with the lens partially extended. Through a series of start/shut off's and hearing clicking noises when the lens fully retracted/extended the camera seems to be working fine. It no longer makes the clicking noise and the lens functions properly. Here's my question...by being dropped is there some internal component inside the camera all out of wack now that affect the quality of the camera's operation and of the pictures it takes? Do I need to send it in for general service/alignment of some kind? Thanks a bunch.
I know I was a tad wordy but the question was will I need to take my camera in for adjustment if it's been dropped a couple of times. The lens seems to be operating fine these days and has nothing to do with the battery charge.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Camera most likely has a short inside, it happens from loose screws on these cameras. You'll need to get it fixed and it's good to do the correction to the screws inside once repaired. The shop that is great for these is: www.camerasandparts.com They only work on Canon Powershot's and they are wonderful for help with these. For $89, they do the repair, the service on the camera and the internal no power correction at the same time, they even cover the cost of the shipping back. They know these cameras well, if you need help with it, they're great for these cameras. Good luck with the problem on yours.
Go with this place: www.camerasandparts.com They charge $89 for the lens error service package on the G9 and they do excellent work. The neat thing with them is they don't just do the repair, they service the camera up as well, plus shipping going back is included in their service package too which is nice. Much more affordable than Canon and they are experts on the Powershots, the Canons are all they specialize in! I hope that helps you with getting it going again.
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
I have fixed my g9 twice with the lens problem. 1st time I dropped the camera on asphalt lens closed. Turned on, lens stuck and not forcusing or retracting. Solution was to press lens against a door frame and push as I turned off the camera...it worked. The next time,the lens was extended and would not retract I had to place the camera on its back on a book while I used a small block of wood and a small hammer. It worked camera is working fine. After both cases, it took about 5 shots to calibrate the auto focus.
Yes it is the lens is exspencive but it canbe replaced. cost on the lens is about 150.00 for parts and labor. could be more or less at other digital camera repair shops.
Your best bet would be to have it serviced by a professional to get you going again, those are really excellent cameras. If you'd like to have it repaired, you can have the G9's repaired here: www.camerasandparts.com This place just does the Canons exclusively, they don't work on any other models. The best part, the work through them is superb and they are not expensive at all. It runs $89 for parts / labor on the repair and the servicing for the camera included. Plus they cover shipping back which we like. The best part is the work through them just excellent on the Canons, they'd be the place if you want to have it fixed. Hope that helps you with it, all the best. That's a great little camera.
A new camera will fix problem perfectly. LOL
Did you drop it? Seem like there might be a short or something similar.
Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
HI
MY G9 WAS DROPPED ACCIDENTLY BY MY SON, AND NOW LENSE ERROR. AM REALLY WORRIED AS MY MOTHER WOULD SCOLD ME AS I SPEND 376 POUNDS ON THAT.
