Here are the instructions, basically you remove the screws on each side and then on side will lift off. I used a flat head screw driver to work around seem until it lifted off. Hope this helps.
http://www.conair.com/instruction_booklets/06PM8043%20BE18NX.pdf
I have a Conair True Reflections make-up mirror and just put in a new bulb, but two white things with metal washers on the bottom of each fell out of the mirror casing when I took it apart and I have no idea where there are suppose to go. Where do I put them and, are they necessary? You CAN replace the bulb and I got mine a Lowe's by just taking the bad one in and they matched the new one. If you remove the four screws, you can get to the fluorescent bulb. Then you have to roll the new bulb into its place. Each bulb is around 8.00 and no matter how old the mirror, you CAN replace the bulb
