Hi, "F02"
is a Long Drain error code. This is an indication that you may have an
obstruction somewhere in the drainage system somewhere. In most cases
this means there is a clog in the drain pump or inlet line running from
the wash tub to the pump. There is a white screw off cap on the drain
pump that you can remove to inspect the pump impeller and clean.
The
"SUD" error code can often occur in conjunction with the "F02" error
code. This is due to air being detected in the drainage system, which
can occur if the pump is not running, or if you have an obstruction
BEFORE the pump. You need to remove the inlet hose from the pump to
ensure it is also not blocked. Correct your drainage system fault, and
the SUD error should go away.
If these preliminary measures do not correct your problem, you may have
to replace the drain pump. It does not take much to damage the pump
impeller or motor. Since the error code is generated if the drain cycle
exceeds 8 minutes, if the pump is damaged and can't pump at the
required volume, the error code will continue to appear until the pump
is replaced.
SOURCE: he4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
SOURCE: Kenmore Elite HE4t Washer
"F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
SOURCE: ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
SOURCE: F2 error code on my kenmore he4t washer
Hi
Thanks
for using FixYa. F/2 error means Long Drain. If the drain time exceeds 8
minutes, the water valves are turned off and "F/02" is flashed. Press
PAUSE/CANCEL twice to clear the display.
Please do rate the solution if
the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: i have a kenmore elite he4t that stiops washing
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
