DISH Network IR Remote Control Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2 remotes and one box. I can not get the second remote to work ..it will only let me watch what is on tv1. I have it set to dual viewing. My tv1 remote works sometimes I think it is inferring with the tv. I have a Vizio 55 inch.
Anonymous
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 358 Answers
  • Posted on Jun 17, 2011
Anonymous
Expert
Level 2:
Legend:
Answers
358
Questions
0
Helped
141371
Points
438
Pkermer,
It sounds like the receiver is in single mode (you said it was in dual mode) or shared viewing. With shared viewing disabled, you will not get a picture on TV 2, only TV 1. If you are not getting a picture (black screen) on TV 2, you should change the setting for Shared View on your receiver.
Make sure your receiver is in Single mode by pressing the Mode button on your receiver (should have only the green light lit on the front of the receiver and the single mode amber light). Press the Menu button on your remote to display the Main Menu on your TV 1. Press 6 (System Setup) and 2 (Shared View). Move the cursor to Enable Shared Viewing. Press Select on your remote (Enable View should have purple dot). Then press Done. Exit out of the other screens till you have a picture on your TV 1 screen. Make sure the receiver is in dual mode and then check to make sure you have a picture on TV 2.
If you have any more problems or questions, please let us know.
Ray Calo
DISH Internet Response Team
Which device button on a signalex 10 in 1 remote control do I press to set a freeview box
Signalex Universal Remote - instructions? ' AVForums
www.avforums.com > ... > Remote Controls
I have the instructions for this model URC22B (SK012) 15-in-1, if you can ... hi jeff,i need to control a goodmans tv, model no 295ns, hope u can help me, ... Press and hold button "SET" and press selected equipment button (ie TV1, .... iv just bought a poundland signalex universal remote which wont pick up my freeview box.
signalex 10-1 poundland remote simplified instructions ' eBay
www.ebay.co.uk > ... > Remote Controls
eBayTo Set Code Find your TV model (or other appliance) code; then you press and holdbutton "SET" and press selected equipment button (ie TV1, TV2, AUX, ...
2answers
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
1helpful
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
1helpful
Dish Network remote and receiver problem
Hi Tracy, my name is Mike Houston a Social Media Representative at DISH. With the TV2 remote working for both TVs, you will want to make sure the TV1 input on the receiver is connected to the TV cable (RCA or Coax cable) and TV2 input is connected to TV2 port on the back of the receiver. I will provide you our link explaining in more detail about connections. If you have any further questions I will provide you my e-mail; [email protected]. Here is the link I promised you: http://www.mydish.com/support/same-video-2-tvs
Tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
How do i change tv 2 with reciever or remote 1, lost remote 2.
Hi this isMike Houston of DISH Network and I see you have lost your TV2 remote. Until youget your 2nd remote you can put the receiver in Single Mode and putTV1 on the channel you want to watch for TV2 and then put it back in Dual Mode.I can help you in getting your TV2 remote so you can watch TV on both setswithout having to change the Mode setting on TV1, I will send you my e-mail andyou can contact me through there; [email protected].
I have a new DVR 622 reciever, the UHF remote(TV2) does not work at all, I have tried to program it, but itdoes not seem to work.(does the TV2 need to be hooked up to the receiver to et the remote to...
Hi Rich, myname is Mike Houston of DISH Network and after going over your post I see theTV2 remote as well as other issues with TV2. There is a easy fix to this so youcan enjoy both TV's, on the receiver you will want to make sure it's in DualMode, you will see a Yellow, Blue and Green lights on the front of thereceiver. I will send a link to help with the steps of setting up the remoteand making sure the TV2 is configured correctly and on the right channel. http://www.dishnetwork.com/SupportSection/troubleshoot
1helpful
2answers
We have 2 led/lcd vizio tv's. (TV1) is a 47"
first off, check the mode setting at tv 1, are you in dual mode, or single. you need to be in dual. Also sounds like the remotes address is not correct. rather then me typeing forever here, I would call dish, 1-800-894-9131, they can walk you rite through it.
Remote (2) works to tun the TV on and off.... But nothing is working in the SAT mode. Remote (1) is working fine.
Hi, Mary with Dish Network Customer Service. I am sorry you are having a problem with your TV2 remote. It sounds like it needs to be readdressed to the Dish receiver box. Take the remote to TV1, using TV1 remote, press the "Menu" button twice. TV screen should show "System Info", towards the bottom of the screen it will say "Primary Remote Address" and "Secondary Remote Address". Take TV2 remote, press and release the "SAT" button, on the top left corner of remote. The press the "Record" button 3 times. The number in the white box, next to "Secondary Remote Address" should have changed, if not unplug receiver from power for 10 seconds and then follow the instructions again. This should resolve your issue but if you are still having a problem, you may need to contact Tech Support directly. I hope this helps.
2helpful
In single mode, my remote for TV1 works, but in dual mode, only my remote for TV2 work. In single mode, both remotes can change channels, record, etc. In dual the Remote for TV2 turns on the blue light and...
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
