Hey 217,
Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush.
You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
SOURCE: I have a Minn Kota Endura 30, transom mount.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
All of the nuts and bolts are metric on it. It helps to use a 13mm swivel socket on the starter bolts but you can use a wrench if you need to. Also, a 7/8 open end wrench for the 02 sensor, or an 02 sensor socket.
Let me give you the steps for the starter and also the front engine mount bracket. You don't have to remove the entire mount, just the bracket
REMOVAL
Remove the battery cable from starter.
INSTALLATION
FRONT MOUNT
REMOVAL
INSTALLATION
