SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes). See link below.
Firmware
Gerben
People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
It has lost it's Ip address or your queu is backed up and has to be cleared.
1 go to Start, Settings, Control panel, printers and faxes is your printer there? No, then download.
2 go back to step 1 right click on your printer and go to properties go to Port put your mouse between the Port and Description line that seperaates them, right click and drag that line over to the right, it will show you the IP address. That has to match the network card IP address try printing a Configuration page from the menu of the printer it will show you what the actual IP is.
Hi Sunil Mahendrakar, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Make and model number of printer ?
Subnet mask setting of your network ?
Subnet mask setting of printer ?
