I had succeed to recover files from crashed hard drive with Asoftech Data Recovery program. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, etc.You can download it and scan your hard drive for free to preview whether your files can be recovered
http://www.asoftech.com/articles/free-data-recovery-download.html
Yes,you can retrieve data from hard drive with data recovery software.I have succeed with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data. Download a trial version and scan your hard drive for free to check out whether your lost data can be recovered.http://www.any-data-recovery.com/index.htm
In your case, there could be three possible
reasons:
1). Accidentally hide your files.
Try to show them all like this: Start >
Run > Type in "control folders" > View > "Show hidden files
and folders"
2). Virus infection.
Some virus also would hide your files
without warning and make you find them nowhere. So, run your antivirus tool to
keep your hard drive clean.
3). Hard drive problem.
Some hard drive problems also would make
your files inaccessible. So, in order to access these files again, you need data
recovery software.
Try to restore these inaccessible files on this hard drive at the help of a drive data recovery freeware:
http://www.freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Card Data Recovery can help you recover data from corrupted hard drive. Have a look.
Don't worry and you can recover the lost data as long as they haven't been overwritten by new ones. And then you can try Cisdem Data Recovery to recover data from your external hard drive.
Step1. Run Cisdem Data Recovery on Mac and connect your external HDD to it.
Step2. Choose a scan mode.
Step3. Choose your external HDD for scanning.
Step4. After scanning, preview and recover the data you want.
For more info:
How to Recover Data from External Hard Drive on Mac
I think Tenorshare Data Recovery Pro can help you, it ever helped me recover files from Window 7 computer.
What if i can say that you can easily get every thing on your hard drive by using Remo Recover Windows free tool and it can restore lost or deleted files from hard drive.
Try "Kernel for FAT and NTFS" data recovery software to recover data, and follow the steps :
1. Get the HDD out of the external casing.
2. Connect the HDD to the Other system as External drive
3. Then run data recovery software on it will take time for the scan to be completed.
4. After scan completed u got d list of files ready to be recovered
5. Recover the files you want to recover.
You hard drive may have failed, but if its still working you can recover the data with a program.
http://www.pcworld.com/downloads/file/fid,23069-order,1/description.html
the program listed above is free and should be able to recover some of you data, some data will be lost forever though.
The Mac and the windows file system are different. So if you
will connect a Mac file system formatted hard drive to a windows system then it
may occur. To retrieve your data from your MAC hard drive you have to connect
the drive to a Mac system.
Check the cables of the hard drive or replace them. You can
try to connect with another port of the mother board. If the Bios don't detect
your hard drive then check the bios settings. If the bios detects your hard
drive but you can't access it then try to repair the OS to retrieve your data.
