Vizio L32 32 in. LCD HDTV Logo
A
Anonymous Posted on Dec 14, 2017
Muchas gracias por su ayuda mi nombre es javier el tv vizio vx20l hdtv al conectarlo da la imagen perfecta lueg de un minuto se pone el color rojo regado en ciertas partes ej .las caras .ventanas .letras como si tuviera demaciado contraste .al apagarlo un momento y volverlo a prender solo dura bien cinco segundos
Larry
Level 3:
  • Vizio Master 5,042 Answers
  • Posted on Dec 14, 2017
Larry
Vizio Master
Level 3:
Answers
5042
Questions
Helped
1241612
Points
18413
5 Related Answers
A
Anonymous
  • Posted on Nov 26, 2007
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Anonymous
  • Posted on Apr 11, 2009
SOURCE: VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Anonymous
  • 10 Answers
  • Posted on May 23, 2009
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
Chi Chu
  • 8457 Answers
  • Posted on Nov 10, 2009
SOURCE: My Vizio VX20L Flat HDMI TV shows
Tries change another HDMI cable,reset all HDMI setting to reset factory setting.
Anonymous
  • 416 Answers
  • Posted on Mar 14, 2010
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
1helpful
Como puedo programar el control de dish para mi televisor panasonic si no tengo los codigos
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle proveendole la informacion que necesita. Unos codigos para la television marca Panasonic que se pueden integrar al control serian los siguientes: 685, 512, 738, and 876. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba del control hasta que los demas botones se enciendan en rojo una vez esto suceda ingrese uno de sus codigos seguido por el signo de numero por ejemplo 685#, el boton de T.V debe de iluminarce 3 veces despues de esto puede tratar de usar su control con la T.V y deberia funcionar. Si necesita ayuda programandolo este link le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup tambien me puede contactar directamente a mi correo electronico a [email protected] Gracias espero que esto le sirva de ayuda.
5helpful
2answers
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
3helpful
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico [email protected]
7helpful
Los pasos a seguir para progamar el ontrol dish al televisor? y los codogos para el tele RCA
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el contol de DISH Network a su T.V el procedimiento es el siguiente: Oprima el boton de T.V localizado en la parte de arriba de su control hasta que los demas botones se enciendan en rojo, una vez encendidos ingrese el numero de codigo que tenga para la marca de su televisor seguido por el signo de numero (#) el boton de T.V debe de iluminarce 3 veces, despues usted puede intentar usar su control y deberia funccionar. Los codigos que puede programar a una television marca RCA serian los siguientes: 503, 020, 633, 805, 725 y el 627. Si tiene algun problema me puede contactar directamente a [email protected] este link tambien le puede servir de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos y ayuda en como programar el control. Gracias y espero esto le sirva de ayuda.
17helpful
5answers
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
1helpful
2answers
Necesito el codigo para sincronizar mi control de dish network con mi Tv marca ELEMENT. Los numeros de la parte de atras del tv son 3.2
Hola mi nombre es Kimberly Escobar con DISH Network. Con mucho gusto le puedo proveer la informacion que necesita. Ciertos codigos que se pueden integrar al control para que funcione con su television Element serian 627 and 659. el procedimiento a programarlo seria precionar el boton de T.V localisado en la parte de arriva hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 627#. El boton de T.V debera iluminar en rojo 3 veces. Despues de este procedimiento puede intentar usar el control, no le podemos prometer que controle totalmente su T.V. En este link puede encontrar mas codigos y ayuda programando su control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita mas ayuda o tiene mas preguntas pro favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda!
No se como progamar mi control remoto de Dish Network por que mi televicion es marca Emerson pero tiene VHS incluido?
Hola mi nombre es Kimberly Escobar y soy representante de DISH Network servicio al cliente. Tengo entendido que necesita ayuda programando su control de DISH Network con su televicion Emerson, seria mi placer asistirle proveendo la informacion necesaria. Para programar el control con su televicion hay un cierto codigo que se integra al control, permitiendole controlar ciertas funciones en la T.V. No podemos prometerle que pueda funcionar completamente el VHS. Uno de los codigos que posiblemente se integren al control para trabajar con su T.V seria el numero 632, El paso a seguir es el siguiente: oprima el buton transparente en la parte de arriva del control que diga T.V, cuando vea que los otros botones se prendan em rojo ingrese el numero 632 seguido por el signo de numero (#), el boton de T.V debe de iluminarce 3 veces. Una vez acabe con este procedimiento puede intentar usar el control con su T.V. Si tiene preguntas adicionales o necesita ayuda puede encontrar nuestra pagina web muy importante http://www.dishnetwork.com/SupportSection/power-scan-instructions tambien puede contactarnos directamente al 1800-333-DISH muchas gracias y espero esto le sea de ayuda.
21helpful
7answers
No puedo programar un dvd sony a mi control de dish network?
Hola! mi nombre es Kimberly Escobar y soy representante de servicio al cliente con DISH Network. Entiendo que necesita programar el control de DISH Network con su Sony DVD. Existe un procedimiento a integrar un c?digo al control de DISH Network que permite que nuestro control pueda funcionar con su DVD, desafortunadamente no podemos prometer que funcione pero definitivamente podemos tratar. El procedimiento es el siguiente: en la parte de arriba en el control va a oprimir el bot?n de AUX hasta que los dem?s botones se iluminen en rojo, una vez se iluminen usted va a ingresar un c?digo (617, 117, o 671) nota: antes de ingresar el c?digo siempre va un numero uno primero por ejemplo (1-617 or 1-117) despu?s de ingresar el c?digo oprima el signo de numero (#), el boton AUX debe iluminarse 3 veces. Despu?s de este procedimiento puede tratar su control para ver si funciona. Si tiene preguntas adicionales o si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH muchas gracias espero que esto le sirva de ayuda!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
