SOURCE: High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
SOURCE: where can I get a guide for rebuilding my ao smith
You won't find one and rebuilding a motor of that nature would be a waste. For starters, once they fail to the point you notice they need atention it is usually to late. Parts are not going to be available and the cost of the replacement is so low it just doesn't make sense to try. A replacement motor is only about $130. If you would like a formal quote or to order one, contact us at www.arrowmotor.net and include the model number (326p203) in your message.
SOURCE: I HAVE A CENTURY LASAR POOL/SPA MOTOR W/ A HIGH
Faulty centrifugal switch, internal, faulty, temp sensor, internal, faulty start run capacitor (If used). bad brushes, (If any) Faulty Winding.
is there a set of jumper pins that need swiched around so it will run on 115V?
