Toshiba Satellite A135 Notebook Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop switches off every time i switch it on...
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Jun 15, 2011
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7912147
Points
102259
If you are not using your laptop on a flat surface, it may beobstructing the cooling vents on the bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
HP Dv5t laptop wont switch on
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
2answers
Where is the wireless switch
On the front edge of the laptop by the right speaker, there is a switch just left of the speaker. That is the wireless switch, to the left of that switch is another and that is the bluetooth radio switch. Below is a link to the service manual that goes over every aspect of your laptop.
http://tim.id.au/laptops/acer/travelmate%204220%202480%20aspire%205600.pdf
1helpful
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Wireless switch
check on laptop right and left side you find 1 switch to turn on wi fi .
Also some times it is in front side of laptop .
you can find easily on laptop.
Acer Aspire 5052 doesnt turn on Pressing power switch first time
have the power switch replaced ASAP please. the contacts to start your laptop is already weak and needs to be replaced. consult a laptop repairs man who specializes in acer manufacture.
1helpful
Laptop wont switch on
remove power cable, battery and all cables attached to ur laptop, then press the power on button for 10 seconds after that attach battery, whatever cables that you had disconnected, and switch on again if doesn't give display and beeps for 3 to 5 times then thats minor or may be ram problem, or if it beeps for 7 times then thats motherboard problem, take ur laptop service centre.
1helpful
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Causing fatal error when not plug into KVM Switch
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
IOGear 2-port KVM Switch
Laptop switch
try to spray the switch with "Contact Spray 90" ur switch maybe oxidised i think it will solve
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
