Hi, Sounds like the lens is just really dirty. Go buy a leans cleaner disk and run it through the DVD player two or three times to get the lens good and clean. Repeat about once a month to keep the lens clean and running properly. Sometimes you need to run it through 3 or 4 times to get the lens to read again.
These disks I speak of have little bristles on it that "sweep" the lens clean. I use them on all my disk players and they work real well.
If you have any comments please feel free to leave them here.
Hello
Put a video CD and see whether it reads and plays. If it also does not plays, or if video CD only plays and not DVD; in both cases; the Laser Pickup Unit is faulty and should be replaced with same type and number. OK.
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
The messagin indicates that the unit recognizes the a DVD is present. Since it goes that far, it suggests that the information read from the disc is wrong. A dirty lens can cause this. Use a cotton swab as Welcomjee suggested dampened with alcohol. If that does not resolve the problem but a CD will play, then the optics are failing and need to be replaced.
Given the cost of replacement optics for your unit, if the optics are bad, replace the unit.
There are two main families of DVD's, the minus (DVD-R/RW) and the plus (DVD+R/W). The most popular is the minus and almost all players can access this types. The newer and better DVD (plus) is not as popular like the minus. SOme players will not be able to read the plus.
Check the DVD that you used, if it is DVD+R, try to use DVD-R
