What I would try is to replace the harddrive and reinstall windows. it seems like the hard drive is bad and can not read it and that will take time if the computer can not read the hard drive very good and will take time to work and if it does not work even to get to the page on the internet. replace the hard drive and reinstall windows. for the harddrive is bad
SOURCE: dell inspiron 1525
did you go into network connections? there you can hit the repair tab this should renew the IP address for you and at the same time recognize your lap top. also you should check that the proxy settings in your lap top match the settings in your desk top. keep me posted.......good luck
SOURCE: Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
SOURCE: Inspiron E1505 - Bad ethernet connection
right clik onmy network places chekc your lan card is enable?
if not enable it.
SOURCE: dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
SOURCE: My ethernet port is not working. I have not used
the most popular solution is installing os........
but if u don't wanna so first u have any cd of your ethernet port....
so u can install second time and enjoy
ok
have a good day
