Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
Code 01(backet full).Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
I tried this and it did not help, thanks anyway.
I did it and it is working
Mine did the exact same thing, I replaced the wiring to the humidity sensor, water full switch and coil sensor, they are all connected to one plug on the board, part no: AP 4652359, COST JUST UNDER $25, it takes about half an hour to replace just remove front and rear covers and then the metal housing, unplug with needle nose, put the new one in the same places, it is an easy fix,m the clip will slide off the coil sensor just work at it alittle, and dont forget to clean the coils while it apart, a wire brush will do the trick just not to hard.
I replaced the sensor assemble AND the bucket switch and am still getting the same error code of 01 Bucket Full. Very frustrating! Not sure what to do from here.
I started at the button since it seemed like the piece with moving parts and therefore most likely to wear an tear.. It was $7 That fixed the problem and of course everything was vaccummed too. Thanks for the previous how to comments. They were helpful. And gave nonalcoholic confidence to start taking it apart!
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
SOURCE: dehumidifier won't turn on
Make sure the buicket is seated all the way. Sometimes it doesnt fully engage on the left side. If it is then it may need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: My LG LHD45EL Dehumidifier is showing a ch 01
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
heatman101
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
