FUJIFILM FinePix XP20 / XP22 Digital Camera Logo
Posted on Jun 14, 2011
FUJIFILM FinePix XP20 / XP22 Digital Camera LCD screen not working. Camera still takes pictures but can't view screen. Camera is brand new just opened on Sunday.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
318
Points
Have you figured it out yet?
tip
How to change time and date in fine pix xp20
first you have to go to setting then select time and date
Water salt
Yes, it's waterproof to 5M. It's always advisable to rinse off the camera with fresh water afterwards however to stop salt build up.
1helpful
2helpful
Don't see time/date stamp on my pictures when viewed on computer or printing
Your camera won't deface your photos by scribbling a string of numbers across them. The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
I want to take a pic of my engagement ring
To take a close up photo of your ring, if your camera has a Macro setting then select this setting, this will allow you to take a very close up photo.
Can i use a usb cable to charge my xp20
No. The camera does not contain charging circuitry. Use the supplied charger or a third-party replacement.
1helpful
How to turn the date stamp on for fujifilm XP20
The date and time (and a lot more) are stored with each image in its EXIF metadata. Consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer, you may be able to print the date on the image, in the margins, or on the back.
1helpful
How do i reset the date and time on xp camera
Hi, When you go into the menu go to the tab that has a little wrench and there'll be options for changing the date.
Top FUJIFILM Cameras Experts
ZJ Limited
ZJ Limited
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
