Minolta X-700 35mm SLR Camera Logo
A
Anonymous Posted on Jun 13, 2011
Minolta x700 will not flash when shutter button is depressed. Also, with the flash attatched, the shutter will open and not shut...like with a long exposure, then when it shuts, the flash will fire. I want a digital slr, but picked this camera up for 25 bucks at a church sale and was hoping to get some use out of it.
Anonymous
Level 2:
Novelist:
  • Expert 98 Answers
  • Posted on Sep 04, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
98
Questions
0
Helped
23439
Points
127
How does it function without any flash attached? If it only malfunctions with this flash attached I'd bet it's an issue with the electronics in a dedicated flash. If that's not the case, either consult a local tech, KEH Camera online, ebay the camera, or scrap it.
X300 and x700 no power
These use two of the L44 common button battery. The + sides of the battery (flat) goes towards the body ... the bump goes towards the battery holder. Check the contacts on the body and where the threads (-) contact the body. Not voltage, no work. Assuming you have 4 different batteries, can you check the batteries ? One bad one of two will not allow voltage. I have bought new button batteries that were dead right from the package. Strange two cameras are dead. They have electronic shutters. The LED should light up in the viewfinder when the shutter is slightly pressed.
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is [email protected]
My daughter just got a used Minolta 700-X. We are trying to load the film, but the advance lever won't advance to load the film after we put it in. Can you help?
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Dec 07, 2008 • Photography
Minolta x-300
The X-300 is very similar to the X-700 minus a few features like program 'P' mode. The VF displays are very similar for metering and exposure. You can read the users guide for the X700 here on
Mar 03, 2008 • Cameras
8helpful
3answers
My X700's shutter isn't working when i press the shutter release
Check for dead batteries first - if not that, the magnet capacitors need to be replaced, or the release magnet cleaned.
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Shutter-release
After the focus is confirmed, the Shutter-release time lag for the DiMAGE E201 is approximately 0.4 second. If the shutter-release button is depressed in a quick motion without making any pause to confirm focus, approximately 1.9 second is necessary.
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
